Problem
As most here, we use PagerDuty OnCall extensively in our team and we have a large team that is very dynamic. We rotate the on-call schedule, and have to manually coordinate our vacation schedules with others on the list (overrides & such, IF we can find someone willing to switch who is also not scheduled for the same vacation time). It’s a bit of a regular awkward hassle. …and then when people are added/removed, the schedule shifts around, and we have to re-coordinate all over for any new conflicts or un-override the switches that are now no longer needed.
While we could continue this process indefinitely via the inefficient/manual combination of Outlook & Slack & PD, it would be MUCH easier if this were automated in PD - even if only slightly less manual.
Proposed Feature Request
If team members could simply put their vacation days into a personal “PD vacation calendar”, then when PD is re-allocating schedules for the users, it could simply skip assigning someone as OnCall during their vacation dates (shift them to before/after their vacation). Then there would be no more regular time-consuming coordination, awkward conversations about switching, re-evaluation every time the roster is re-shuffled with new persons, etc. Overrides would then only be needed for cases of emergencies or oversights.
An automated approach like this would reduce a lot of overhead across our team. I figured I would raise the feature request, because I’m guessing we’re not the only team regularly impacted by this issue.
Thanks for the consideration!
Clint
